Results 1 to 6 of 6
Thread: Select polyline and get coordinates
    2011-08
    Vadodara, India
    147
    Default Select polyline and get coordinates
    Dear friends,
    I am creating the Standalone application in the VB.Net. and I need a solution for Polyline coordinates by select object.
    can anyone have this solution.
    Avinash Patil
    2009-11
    5,719
    Default Re: Select polyline and get coordinates
    You should be able to cull what you need from here:
    Iterating through a polyline's vertices using AutoCAD .NET
    Computer Specs:
    2006-08
    Brisbane : GMT+10
    87
    ... except for the 'StandAlone' part.
    You must run AutoCAD to make use of the AutoCAD .NET dll's
    2009-11
    5,719
    Quote Originally Posted by Kerry Brown View Post
    Guess I go thrown off by the 'select object' part... My thought was actually to code a Method that accepts a BDObject as an argument, from which one would test for Polyline or Polyline2d, etc..
    I 'spose a COM alternative is need instead?
    Computer Specs:
    2006-08
    Brisbane : GMT+10
    87
    I am creating the Standalone application in the VB.Net. < .. >
    I guess this needs clarifying. What does Avinash Patil mean by 'StandAlone' ?
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Show us your code how you've to select this polyline,
    then we will go further this way,
  1. Polyline Coordinates finding
    By avinash patil in forum VBA/COM Interop
    Last Post: 2012-08-30, 11:29 AM
  2. 3D Polyline coordinates
    By lmitsou in forum AutoLISP
    Last Post: 2008-07-17, 08:49 PM
  3. Polyline with circe center coordinates
    By lee.harte.166277 in forum AutoLISP
    Last Post: 2008-04-17, 08:41 AM
  4. Replies: 8
    Last Post: 2007-06-07, 07:53 PM
  5. Replies: 8
    Last Post: 2007-03-12, 11:30 AM
