BIMster
No, I was actually wanting to incorporate it for design calculation purposes. From my knowledge about water supply design (which is somewhat limited), the most accurate way to design a system is to design by friction (rather than velocity method). Doesn’t this require the service pressure to the building? I just don’t see how you can be sure that you have adequate pressure on the upper floors without knowing this. My understanding could be really off.
IPC instructs designers to figure out the water service pressure, subtract static head pressure loss, and subtract other equipment (such as water meters and softeners); leaving you with the pressure available to overcome pipe friction.
