Originally Posted by
rkmcswain
Specific answer to that question:
Set NOMUTT to 1, which in itself is a good one if the user doesn't know this sysvar.
This still shows at the command line, unless loaded via LISP (which also shows at the command line if dragged into the editor), and followed by a (princ) call.
Command: e
ERASE
Select objects: Specify opposite corner: 1 found
Select objects:
Command: (setvar 'nomutt 1)
... Further, it makes it so that the line you just entered is _literally_ the last line visible. LoL
Instead, just 'veto' a small handful of commands, by Blocking AutoCAD commands from .NET. Lemon squeezy.
