Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Rotate multiple blocks about the insertion point to global fixed point.
    2015-09
    154
    Default Rotate multiple blocks about the insertion point to global fixed point.
    Hi,
    Could anyone assist me in modifying the following code that I found to enable the following:
    step 1:Select blocks
    step 2: Select a single point that all blocks should point towards (blocks are arrows and all have to point towards mecca)
    step 3: then using the rotate command on each block
    base point = insertion point
    use a reference angle of 90
    for the new angle it should use a point (that being the point selected in step 2)
    ;RotBlock.lsp by Maurizio
    ;Start code
    (defun C:RotBlock ()
    (princ “nSelect blocks: “)
    (setq grp (ssget))
    (setq rotAngle (getangle “nRotation angle: “)) ;
    (setq rotAngle (atof (angtos rotAngle 0)))
    (setq j 0)
    (repeat (sslength grp)
    (setq eName (ssname grp j))
    (setq pt (cdr (assoc 10 (entget eName))))
    (command “_rotate” eName “” pt rotAngle)
    (setq j (1+ j))
    ;End code
    for me I need to change this to
    to (setq Rotangle (getpoint "nRotate block to point: "))
    and this line
    to (command "_rotate" ename "" pt "_r" "90" "_p" rotangle)
    but that does not do it.
    any ideas? I thought it strange that I was not able to find a similar lisp online.
    Any help much appreciated.
    thanks
    Ontario, Canada
    116
    Default Re: Rotate multiple blocks about the insertion point to global fixed point.
    This is necessarily basic, as I am unfortunately pressed for time, but it should do what you seem to be requesting...
    (defun c:pointat ( / ARRW-N ARRWS N N-PT NUM PTA)
      (vl-load-com)
      (if (setq arrws (ssget '((0 . "INSERT")))
    	    ); setq
        (progn
          (setq num (sslength arrws)
    	    pta (getpoint "\nPick the Target... ")
    	    n 0
    	    ); setq
          (while (< n num)
    	(setq arrw-n (vlax-ename->vla-object (ssname arrws n))
    	      n-pt (vlax-get arrw-n 'insertionpoint)
    	      n (1+ n)
    	      ); setq
    	(vla-put-rotation arrw-n (angle n-pt pta))
    	); while
          ); progn
        (prompt "\nNo blocks selected. ")
        ); if
      (princ)
      ); defun
    All AUGI, all the time Tharwat's Avatar
    2010-06
    917
    This may not give you the right direction if your blocks are not on zero angle , anyway try it and i can modify it if you in need of any .
    (defun c:Test (/ ss i sn gr)
      ;; Tharwat 02. Oct. 2012 ;;;
      (if (setq ss (ssget "_:L" '((0 . "INSERT"))))
        (repeat (setq i (sslength ss))
          (setq sn (cons (ssname ss (setq i (1- i))) sn))
      (while (eq (car (setq gr (grread t 15 0))) 5)
        (redraw)
        (foreach b sn
          (entmod
            (subst
              (cons
                50
                (- (angle (cdr (assoc 10 (entget b))) (cadr gr)) (/ pi 2.))
              (assoc 50 (entget b))
              (entget b)
      (princ)
    All AUGI, all the time pbejse's Avatar
    2010-10
    535
    (defun c:Test (/ ss i sn gr rp)
        (redraw)
        (foreach b sn
          (entmod
            (subst
              (cons
                50
                (- (angle (setq rp  (cdr (assoc 10 (entget b)))) (cadr gr)) (/ pi 2.))
              (entget b)
          (grdraw rp (cadr gr) 1 1)
      )(redraw)
      (princ)
    2010-06
    917
    I completely forgot about grdraw function .
    Thanks pBejse .
    2015-09
    154
    Hi GHarvey,
    Thanks for your help. This works in principle although there appears to be a little problem in that each block rotates what appears to be an extra 90 degrees.....any ideas?
    2015-09
    154
    Hi Tharwat,
    Thanks for your help. I have problem with selecting the target point. I cannot snap to anything or insert coordinates at the command line. It works if I just select a random point on the screen. Any ideas on what I might be doing wrong.
    Thanks for the help guys
    2010-06
    917
    You did not do anything wrong , but I used the grread function for graphic action ,
    but anyway here is another one according to have mentioned in your last post .
    (defun c:Test (/ ss p i sn)
      ;; Tharwat 03. Oct. 2012 ;;;
      (if (and (setq ss (ssget "_:L" '((0 . "INSERT")))) (setq p (getpoint "\n Specify target point :")))
          (setq sn (ssname ss (setq i (1- i))))
          (entmod (subst (cons 50 (- (angle (cdr (assoc 10 (entget sn))) p) (/ pi 2.)))
                         (assoc 50 (entget sn))
                         (entget sn)
      (princ)
    2015-09
    154
    hi,
    that's does exactly what I need, thanks for your help. Much appreciated.
    This thread is now "Solved"!
    thanks Tharwat
    2010-06
    917
    Quote Originally Posted by feargt View Post
    hi,
    thanks Tharwat
    You're welcome anytime .
  1. Rotate objects by insertion point
    By spattn in forum VBA/COM Interop
    Last Post: 2011-11-05, 05:24 AM
  2. Display cooridinates of a blocks insertion point
    By JH75 in forum Dynamic Blocks - Technical
    Last Post: 2009-01-06, 05:06 AM
  3. Pick to Rotate at Insertion point
    By BCrouse in forum AutoLISP
    Last Post: 2007-07-13, 09:22 PM
  4. Select blocks by name and insertion point?
    By keelay711 in forum AutoLISP
    Last Post: 2006-10-17, 12:03 PM
