Thread: Current Sheet (Set) Custom in Sheet Set Manager
    2012-09
    6
    Default Current Sheet (Set) Custom in Sheet Set Manager
    Hi all,
    I am having an issue where I am trying to get the CurrentSheetCustom and the CurrentSheetSetCustom field areas to work properly. When I go to insert at field in a block and go to the CUrrentSheetSetCustom or the CurrentSheetCustom, and go to the Custom Property Name drop down box, there is nothing there, as seen in the following picture:
    However, if I go to the specific sheet set, I can find the custom properties that I have created, as shown in the following picture:
    So, my question is: Why is there nothing in that 1st drop down box? Do I need to add these custom properties to a "global" setting of some kind? And if so, how can I do that?
    ~Thanks
    9,805
    Default Re: Current Sheet (Set) Custom in Sheet Set Manager
    In your first screenshot.....are you working in a layout that is part of the Sheet Set?
    I've seen many occasions where users will be working in a drawing, setting up the fields, and the drawing/layout is not part of the SS.
    In this case, the custom properties will not show up.
    You can either work on a layout that is part of the SS, or add your working drawing to the SS temporarily.
    2012-09
    6
    Yes, the drawing is part of the sheet set. Basically, I took our title block file, made it the "Sheet creation template," and created a new sheet. I then started to edit the areas that I wanted to be fields, but trying to think that I would want more "generalized" fields for future sets, I was trying to use the "currentsheet" fields so that when I create a new set in the future, I do not have to add all these custom properties again, and add all the fields again. So, to my understanding, the "CurrentSheet" fields are more generalized, whereas the fields I was setting up in my second screenshot are just specific to that sheet set.
    So, I guess I am wondering if I can add these "custom properties" I have been adding to this sheet set..... to all future sheet sets when they are created?
    2015-10
    158
    Even if the drop-down portion isn't working properly, or isn't in a file that's associated with a sheet set containing that custom property, you can type it in manually and it should work (as long as, of course, it's used in a file associated with a sheet set containing an EXACT MATCH custom property).
    2012-09
    6
    I believe one of the problems I have discovered is that in the "Enhanced Attribute Editor," a couple of the "Values" were changed. However, if I delete the values, all that is left is a blank space, which I think the editor sees as me trying to 'override' the default values. How do I get these values to reset to their default values? Meaning, how can I get the value to not be overwritten and read the value in the attribute definition?
    Correct me if I am wrong, but I think this is what ATTSYNC is supposed to do. However, when I do that, my block disappears.
    2012-09
    6
    I have also tried RESETBLOCK, but that didn't seem to do anything. It doesn't make the block move, or reset any of the text.
  1. Replies: 1
    Last Post: 2014-11-20, 12:27 AM
  2. Create Sheet Lists and Total Sheet Count for Subsets in Sheet Set Manager
    Last Post: 2008-10-12, 06:30 PM
  3. FIELDS ( current sheet custom )
    By pangell in forum AutoCAD Fields
    Last Post: 2005-06-07, 04:54 PM
  4. Current Sheet Set Custom
    By jkipfer in forum AutoCAD Fields
    Last Post: 2005-05-13, 01:22 PM
  5. Plot a Custom Title Block from Sheet Set Manager
    By luke.siebert in forum AutoCAD Plotting
    Last Post: 2005-02-23, 01:56 PM
