Am I doing something wrong? Is it because I don't have project path files set up properly and it freaks out?
How to crash:
1) create an IPT
2) create IAM
3) Insert IPT from step 1 into IAM
4) Create new part inside IAM on surface of first IPT
5) Click New Sketch
6)Crash
Every single time.
Dell Precision T3500
Intel Xeon W3550 @ 3.07 GHz
12 GB Ram
64 Bit Win 7 Pro Service Pack 1
NVIDIA Quadro 600 Driver Date 4/27/12 - Version: 8.17.12.9670
I was running with Graphics set to Quality with software graphics unchecked. After I crashed a few times, I changed to performance and checked the Software Graphics Box.
I'm going to uncheck software graphics and change to compatibility, but I have a bad feeling it is going to crash again.
Thanks...
Daniel
Edit: Found the Diagnostics Button
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
NVIDIA Quadro 600
Direct3D 10
Hardware Renderer
Graphics driver file nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um is version 8.17.0012.9670
Using Full optimization (this is the recommended setting)
The display is using 32-bit color
Inventor Version:
Build: 138, Release: 2013 RTM - Date: Thu 03/01/2012
64-Bit Edition - 8192.00 GB
Loaded Inventor Add-Ins:
Assembly Bonus Tools
iCopy
System Information:
Operating System: 64-bit Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Precision WorkStation T3500
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A13
Processor: Intel(R) Xeon(R) CPU W3550 @ 3.07GHz (4 CPUs), ~3.1GHz
System Memory: 12288MB RAM
Dedicated System Memory: 0MB
Shared System Memory: 5886MB
Dedicated Video Memory: 978MB
Page File: 7832MB used, 16736MB available
DirectX Version: DirectX 11
DxDiag Version: 6.01.7601.17514
Graphics Device Information:
DirectX Version: 10.0
Renderer: HAL
Adapter Description: NVIDIA Quadro 600
DDI Version: 11
DDI Version Number: b
DxDiag WHQL Level: 0
Driver Signed Valid: True
Driver Signed: True
Manufacturer: NVIDIA
Chip Type: Quadro 600
DAC Type: Integrated RAMDAC
Revision:
Vendor ID string: 0x000010de
Device ID string: 0x00000df8
Graphics HW Memory: 2769 MB
Display Mode: 1920 x 1080 (32 bit) (60Hz)
VendorID: 10de
DeviceID: df8
SubSystemID: 83510de
Revision: a1
Graphics driver file: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver file version: 8.17.0012.9670
Driver Date: 4/27/2012 06:27:00
WHQL Level: 1
Inventor Graphics Device Information:
Graphics Hardware Description: NVIDIA Quadro 600
Hardware Library ID: Direct3D 10 \ 0x000010de \ 0x00000df8
Direct3D Hardware ID: 10de \ df8 \ 83510de \ a1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Inventor Hardware Library Information:
HW Library Version = $Revision: #1 $
HW Library Date = $DateTime: 2012/01/16 14:29:46 $
HW Library OS Name = Windows 7 x64
Inventor Hardware Library Entry Information:
Autodesk Inventor Certification Status: Gold
Autodesk Inventor Tested Certification Status: Unknown
Graphics HW Vendor Supported for Autodesk Inventor: False
Hardware Library 2.0
Settings for optimized and conservative:
Workarounds: 0x00000000, 0x00000000
rating 4, optimization level 2
Texture Font Precision: 256
Display Information:
Back Buffer Format = DXGI_FORMAT_R8G8B8A8_UNORM
Depth Stencil Buffer Format = DXGI_FORMAT_D24_UNORM_S8_UINT
Monochrome Bitmap Format = DXGI_FORMAT_A8_UNORM
Graphics driver log information:
Oct/04/2012-08:16:01: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Oct/04/2012-08:16:41: User changes the graphics driver manually: D3D10 -> D3D11.
