Hi,
Can anyone assist me with the following issue.
I have a dynamic block with multiple visibility states. (Vis1 to Vis5 for example)
In each visibilty I habe two unique attributes.
So in Vis1 has two attibute tags called Length1 & Width1
........Vis2 has two attibute tags called Length2 & Width2
I want to get the value of the attributes in the current visibility state and save them as variables Var1 and Var2.
The only joy in searching was what I found on Lee Mac's website but I have not been able to make any progress with his code. (see below)
Thanks for any help on this
Get Attribute Value
Select all ;;----------------=={ Get Attribute Value
;; Returns the attribute value associated with the specified
;; tag, within the supplied block, if
present.
Author: Lee Mac, Copyright © 2010 - www.lee-mac.com
Arguments:
;; block - VLA Block Reference
Object
;; tag - Attribute
TagString
Returns: Attribute TextString, else
nil
(defun LM:vl-GetAttributeValue ( block tag )
(setq tag
(strcase tag))
(vl-some
(function
(lambda ( attrib
(if (eq tag (strcase (vla-get-Tagstring
attrib)))
(vla-get-TextString
attrib)
(vlax-invoke block
'GetAttributes)
(defun c:test ( / ss )
(if (setq ss (ssget
"_+.:E:S" '((0 . "INSERT") (66 .
1))))
(princ
(LM:vl-GetAttributeValue
(vlax-ename->vla-object (ssname ss
0))
(getstring "\nSpecify Tag String:
(princ)
(vl-load-com)
;;----------------=={ Get Visibility State
;; Returns the value of the Visibility Parameter of
a ;;
;; Dynamic Block (if
present)
Author: Lee Mac, Copyright © 2011 - www.lee-mac.com
Arguments:
;; block - VLA (Dynamic) Block Reference
Object
Returns: Value of Visibility Parameter, else
nil
(defun LM:GetVisibilityState ( block )
(lambda ( name
(vl-some
(function
(lambda ( prop
(if (eq name (vla-get-propertyname
prop))
(vlax-get prop
'value)
(vlax-invoke block
'getdynamicblockproperties)
(LM:GetVisibilityParameterName
block)
