Results 1 to 7 of 7
Thread: Dinamic Block
    2012-08
    111
    Question Dinamic Block
    Hey, guys
    I want to create a dinamic block, but I don't know how Can I do. Because there are a lot of situation and I'm lost.
    I need some suggestion.
    Could you see the attached file, please??
    I'm sure you'll understand better.
    DINAMIC BLOCKS.dwg
    Thanks in advance.
    Best Regards
    2016-02
    Singapore
    70
    Default Re: Dinamic Block
    Quote Originally Posted by BILLYJOW View Post
    Hey, guys
    DINAMIC BLOCKS.dwg
    Thanks in advance.
    Best Regards
    try this one :
    2012-08
    111
    Hi nod684,
    Your dinamic block is awesome !
    You have a good idea, as always.
    Now, I'm going to introduce more situation in your block.
    Thanks for help me out again, bro.
    Regards
    2012-08
    111
    Hi,
    Why did you used the lookup1 parameter in the dinamic block??
    Thank in advance
    2016-02
    Singapore
    70
    Hi nod684,
    Regards
    no problem glad to be of help
    Hi,
    Thank in advance
    its a mistake. you can use visibility parameter only
    no need for Lookup
    2007-05
    2
    Two questions:
    1 - What,s LOOKUP parameter for?
    2 - I have a door in a block dynamic. The visibility parameter are ok. How do I link visibility to annotative scales. I explain - a viewport in a scale I want total visibility state, and in another viewport with other scale I want another visibility state
    2009-01
    B5
    544
    1. Lookup Parameter can allow several Parameters to be manipulated to a predetermined set of values.
    2. Cannot do this. The Viewport looks at the DynBlk in Modelspace unless you are placing the DynBlk in PS and in that case just change the Vis State.
  1. Help - Dinamic block
    By BILLYJOW in forum Dynamic Blocks - Technical
    Last Post: 2013-01-22, 12:06 PM
  2. Visibility States - Dinamic Block
    Last Post: 2012-11-30, 04:13 PM
  3. 2012: DINAMIC BLOCK
    By Scooby in forum Dynamic Blocks - Technical
    Last Post: 2012-08-27, 02:26 PM
  4. HELP - DINAMIC BLOCKS
    Last Post: 2012-08-24, 04:59 PM
  5. Highlight Last Opened Block in Block Editor Block List
    Last Post: 2008-10-11, 09:03 PM
