Thread: World File import - File path length limitation
    2006-06
    9
    Exclamation World File import - File path length limitation
    Hi all
    I wonder if someone can confirm this for me.
    It would appear that there is a path name length limitation when inserting an image with an associated world file (.jgw in my case).
    I have had issues lately where an image would insert okay from one folder but not another. I have since realised that the images that do not pick up the world file are in folders with a long path name. It would appear that there is a limitation somewhere around 128 characters, any longer than this and Map does not pick up the corresponding world file in the same folder as the image.
    Anyone else picked up on this?
    Cheers
    TN/KY Area
    1,640
    Default Re: World File import - File path length limitation
    There are/were issues with long paths/file names with the map import and export. So I would not rule it out with images as well.
    2006-05
    Honolulu, HI
    13
    Confirmed, I ran into the file path limit yesterday and only figured it out this morning. I didn't figure out the maximum allowable file path length, but I did have a path that was 130 characters long and Map couldn't find the world files.
    Marv
    Quote Originally Posted by carl.lowrey View Post
    Hi all
    Cheers
  1. Import Project Support Search Path, not via an ARG file
    By Ms. Serene in forum AutoCAD Customization
    Last Post: 2015-06-01, 06:31 PM
  2. Replies: 0
    Last Post: 2011-11-03, 07:10 AM
  3. Print Spooler File Location or Printer Description File Search Path?
    By archer1684 in forum CAD Management - General
    Last Post: 2011-04-14, 07:13 PM
  4. Import AutoCAD file = huge Revit file
    By rob.127056 in forum Revit Architecture - General
    Last Post: 2006-12-04, 02:23 PM
  5. World File
    By terry.83301 in forum AutoCAD Map 3D - General
    Last Post: 2005-04-27, 04:52 PM
Tags for this Thread
