Hello,
I have a dynamic block (attached) that has two bridge symbols on two different layers for two different types and scales of county maps. That part works fine. I need to attach an attribute to the block that allows me to fill in the bridge number. Right now the text is perpendicular to the bridge which I want (most of the time). The issue is that when I insert the bridge block on a road that is slightly skewed, say 10 degrees, that the attribute rotates that much too. I have it unlocked and it does allow me to move the attribute, which I like in the cases that I have bridges too close together, this allows me to re-possition the attribute. What I would like to be able to do is on those locations that are skewed is to rotate the attribute back to either vertical or horizontal (depending on a North-South roadway or an East-West roadway). Is this possible? Any other ideas?
Thanks in advance for any help.
Daryl
