Thread: URGENT HELP NEEDED - SECTIONS - SEGMENTS - GRADE LABELS
    2012-06
    12
    Angry URGENT HELP NEEDED - SECTIONS - SEGMENTS - GRADE LABELS
    I don't know whats wrong with my segments' grade labels. I have this section which is 2.0 + 3.6 + 3.6 + 2.0 assembly. And i should get only one grade label for each 3.6m section but i am getting more than 1. I dont know what is wrong. I have uploaded the drawing to following URL.
    http://www.mediafire.com/?aazh4iv1wn9q13b
    2015-12
    Usak/Turkey
    4
    Default Re: URGENT HELP NEEDED - SECTIONS - SEGMENTS - GRADE LABELS
    Hello,
    You should change label weeding distance. Probably your weeding distance is zero. Click the 'Edit Label' you will see 'Weeding' on same line with Segments and change it as 3.
    Good Luck.
  1. Profile Grade Labels
    By jacunningham428299 in forum AutoCAD Civil 3D - General
    Last Post: 2012-12-05, 05:18 PM
  2. New PC advice - Urgent opinions needed!
    By turnbullp in forum Hardware
    Last Post: 2012-04-02, 04:36 PM
  3. Urgent help needed - I need to view Pro/E 3d model
    By johnd in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-10-20, 02:34 PM
  4. urgent help needed!
    By mckenziewesley in forum Inventor - General
    Last Post: 2008-04-25, 03:02 PM
Tags for this Thread
