[Disclaimer:C# and Revit API Newbie) Here's what I'm trying to do:
A. Iterate through all instances of the "Weld Symbol" family. (I want to iterate *all* types, which will include "Bottom," "Top," "Both," and "None")
B. (Assuming I've located the first instance) temporarily store the values for a number of the instance's parameters.
C. Replace the instance with the same type from the "Weld Symbol (MKA)" family. I want to do this programmatically, because if I do it by simply doing a "Select all instances" command, the parameter settings all get removed.
D. Set the now-reset parameters with the stored parameter values
E. Move on to the next instance.
From locating and trying many examples, below is the code I've gotten to work so far. Obviously, it only locates instances named "Top" from ANY family.
string prompt;
//Get the application
UIApplication uiApp = commandData.Application;
//Get the document
Document doc = uiApp.ActiveUIDocument.Document;
//Create a filtered element collector based on the document
FilteredElementCollector collector = new FilteredElementCollector(doc);
//Set the collector to look for a particular class
collector = collector.OfClass(typeof(FamilySymbol));
//var query = from element in collector where element.Name == "Bottom" select element;
var query = from element in collector where element.Name == "Top" select element;
//Create a list from the query
List<Element> famSyms = query.ToList<Element>();
//Get the element ID of the first family symbol
ElementId symbolId = famSyms[0].Id;
//Create a new filter to look for elements matching the element ID
FamilyInstanceFilter filter = new FamilyInstanceFilter(doc, symbolId);
//Reset the collector?????????????????
//Create an indexed collector of element type instances which pass the symbolId filter
ICollection<Element> familyInstances = collector.WherePasses(filter).ToElements();
//Report the number of family type instances found
prompt = "Count = " + Convert.ToString(familyInstances.Count);
TaskDialog.Show("Revit", prompt);
And, my questions are:
1. (Step A, above) How do I filter for all instances of a particular family?
2. Any suggestions how to proceed with Steps B, C, D, and E? (Please see disclaimer at the top of the post) LOL
3. In my code, what is the need for the step reading "collector = new FilteredElementCollector(doc);?"
Thanks, in advance, for your help and suggestions.
