Thread: Created Surface from polyline contours
    Angry Created Surface from polyline contours
    I created an existing surface from some contours in order to fully use C3D's surface functionality. After creating the surface, I want to delete the contours I used to create the surface because they are redundit in a sense. Problem is, if I erase them, then C3D wants me to update the surface and everything disappears. Is there a way to remove the polylines I used to create the surface without destroying the new surface?
    2010-08
    40
    Default Re: Created Surface from polyline contours
    uh yes, you can create a "snapshot" of the surface(right click on surface name in prospector, create snapshot), which i beleive freezes the definition, then you can remove the plines. Of course, if you ever need to change the surface, then you have to add back the definition objects.
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,447
    Another way to do it would be to add points along the contours and then use those points as your surface data and delete the contours after rebuilding the surface using the point group you created.
    2012-05
    93
    Quote Originally Posted by Tom.Weinstein.137333 View Post
    I think the safest way to get a "clean" surface without any source definition, is:
    1] _LANDXMLOUT
    2] erase the contours and the existing surface
    3] _LANDXMLIN
    Quote Originally Posted by Novarese View Post
    1] _LANDXMLOUT
    3] _LANDXMLIN
    BRILLIANT! Great suggestion, thanks.
  1. level of accuracy for contours created using google image
    By Mohmed_Zuber in forum AutoCAD Civil 3D - General
    Last Post: 2011-03-16, 09:41 PM
  2. Surface from Civil 3d contours
    By jmoore.136085 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2008-08-22, 08:22 PM
  3. Surface From Contours
    By khalidisi in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2008-07-28, 04:53 PM
  4. Surface Anomaly w/contours
    By mpeterson79 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2007-09-26, 02:04 PM
