Thread: Apply button shows changes in model space immediately.
    Wish List Administration
    2011-08
    4,581
    Default Apply button shows changes in model space immediately.
    Summary: For the changes made in the point label style to show immediately in the model space without having to get out of the command.
    Description: Currently most of the commands under the point label style require you to hit ok and get out of the command before the changes show in model space. Hitting the apply button does not do anything while still in the command. Hitting only the ok button does the same as hitting the apply and ok buttons. Currently the apply button does not show the changes such as text height in the model space.
    Product and Feature: AutoCAD Civil 3D - Points
    Submitted By: Julie Fehringer on 10/31/2012
    2003-07
    574
    Default Re: Apply button shows changes in model space immediately.
    Revamp the whole way you interact with styles for me I have a toolbar with it all preset including None just pick what you want 0.1 conts 0.5 conts etc Hts, XYZ
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    The behavior you describe is as designed. There is usually a dialog box showing where you select the style to edit. When you start editing, the apply button does apply the changes, however, the style cannot be graphically updated until the original dialog box is closed.
    I would recommend locating the style you wish to change through the Settings tab of the Toolspace palette. When editing the style through this palette, the apply button works as desired.
  1. 2011: Text shows up in Model Space but not Paper Space
    By rbelling974531 in forum AutoCAD General
    Last Post: 2015-12-03, 12:22 PM
  2. New model lines immediately locked
    By philipdurban in forum Revit Architecture - General
    Last Post: 2012-08-21, 03:46 PM
  3. Replies: 9
    Last Post: 2009-02-25, 10:12 PM
  4. Model space/paper space button
    By david.laetsch in forum AutoCAD General
    Last Post: 2008-07-25, 12:45 PM
  5. Paper/Model Space Button
    By kevin.x.wilson in forum AutoCAD General
    Last Post: 2007-12-07, 02:47 PM
