Thread: Photo Callout?
    I could stop if I wanted to Griff's Avatar
    Idaho
    295
    Default Photo Callout?
    We use photos for demolition work all the time. There is no Photo Callout symbol in Revit so a while back we made a Generic Annotation Photo head (which looks like a callout bubble with dumb text) and we created a Generic Annotation Arrow that we can insert onto the Generic Annotation Photo head and then rotate it around to the view that the photo was taken.
    I hate using dumb text. That defeats one of the main joys of Revit. Is there a way to create a photo callout with smart text that follows the photo?
    Dave Griffith
    2006-09
    6
    Default Re: Photo Callout?
    You can set up your photos in individual drafting views - use the elevation marker and reference the drafting views before placing the marker. Rotate as necessary.
    Idaho
    295
    Thanks for the reply Megan,
    This just might work,,,, curious, is there a way to rotate the elevation (just the arrow) and keep the bubble readable?
    Dave Griffith
    AUGI Addict jsteinhauer's Avatar
    2015-11
    Madison, WI
    1,317
    You don't rotate the elevation view arrow itself. Instead rotate the circle the arrow attaches to.
    Cheers,
    Jeff S.
    'When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.' - R. Buckminster Fuller
    2006-09
    6
    The text should stay readable when you rotate an elevation. If you click on it, there is a tiny rotate icon that will show next to the symbol - you can click this and rotate without having to use the rotate command.
    Idaho
    295
    Sorry it took so long to reply. I tried to reply yesterday but my network connection kept failing. I just want to thank you both for showing me how to fix this problem. I had not even thought about using an elevation callout. I've been doing it this old way for a couple of years. What a waste. Smart callouts are the only way to go, less chance of error. Thank you both SO MUCH!!!
    Dave Griffith
  1. I wish the Callout tool had the ability to make the callout boundary any shape.
    Last Post: 2017-10-13, 10:14 PM
  2. A photo align tool for creating photo montages.
    Last Post: 2010-04-20, 04:06 PM
  3. Replies: 2
    Last Post: 2006-11-27, 04:43 PM
  4. photo montage
    By Martin P in forum Revit - Gallery
    Last Post: 2003-05-09, 01:07 PM
