Thread: Files from Educational Versions
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default Files from Educational Versions
    We received a file from a sub recently that keeps popping up a warning about being from an Educational Version of ACA. This pretty much means that the file is useless since anything we do with it has the educational watermark on the borders. Is there anything we can do other than have them use a commercial version of CAD to be able to use the data in the file?
    This aggression will not stand. Man.
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    Default Re: Files from Educational Versions
    Quote Originally Posted by .chad View Post
    Report em... http://usa.autodesk.com/adsk/servlet...3112&id=340446
    In the meantime I believe you have to retrace everything with a legit copy for it to lose the popup...although I thought the watermark went away when opened with a legit version? Have you tried saving the file from your version and reopening it?
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink or :whiskey: or :wine:"
    2015-12
    2,095
    NO IT DOESN'T. (yeah, that needs to be yelled) Otherwise, what would be the point of the stamp if it could be removed so easily?
    First, report it to the sub. They may be using an intern/student who was trying to do things at home, and both of them may not realize the problem exists. If the problem persists report it to the authorities.
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    2006-04
    1,129
    Quote Originally Posted by dgorsman View Post
    It was an intern that worked on it at home. We talked to them and it's straightened out. thanks!
  1. What's New files for old versions
    By DaveP in forum Revit Architecture - General
    Last Post: 2011-02-08, 08:56 PM
  2. Saving 2007 files to lower versions
    By Detsenira in forum AutoCAD General
    Last Post: 2008-01-09, 05:03 PM
  3. Converting files into previous versions
    By tbell in forum Software
    Last Post: 2005-03-23, 10:39 PM
  4. Replies: 2
    Last Post: 2004-10-14, 05:14 PM
  5. Installation - upgrades & new versions, The Help Files
    By Steve_Stafford in forum Revit Architecture - Wish List
    Last Post: 2004-01-21, 05:07 PM
