Thread: "Cannot open local and central model in same session"
    2004-06
    Memphis TN area
    7,048
    Default "Cannot open local and central model in same session"
    Just a moment ago I used Insert Views From File to bring in a schedule from another project. I chose the project, and chose the schedule from the view list. Shortly after that, I tried to open that other project to copy/paste some stuff to my current project. For some reason Revit thought that other project's central file was still open, and gave me the message that the local and central file could not be open in the same Revit session.
    Is there any fix for this other than closing out of Revit completely and reopening?
    2015-11
    Fredericton, Canada
    16
    Default Re: "Cannot open local and central model in same session"
    Quote Originally Posted by patricks View Post
    Rinse and repeat. Revit 2014.
    Judging from the overwhelming response... apparently not.
    2005-01
    3
    Open and detach from central. Save back as new central file.
    2015-11
    12
    I had never run across this before, but it happened to me today, under the same circumstances as the O.P. And yeah, still apparently no other fix than closing Revit or detaching. I'm going to post this on the Autodesk forum so at least it's there and someone might see it. Not that they'll do anything about it, but worth a try anyway.
  1. Replies: 0
    Last Post: 2014-11-13, 11:05 PM
  2. Replies: 1
    Last Post: 2013-07-16, 04:36 PM
  3. Erroneous "Cannot open central + local model" error message
    By Rustle in forum Revit Architecture - General
    Last Post: 2010-09-13, 04:54 PM
  4. "Central File locked" message pops up when no one else is working on the model
    By Steve Mintz in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-08-08, 03:47 AM
  5. "Open then Save to Central" button
    By Haden in forum Revit Architecture - Wish List
    Last Post: 2006-07-27, 02:05 PM
