Thread: Data Shortcuts - Drawing not yet saved error...
    2010-10
    24
    Default Data Shortcuts - Drawing not yet saved error...
    I keep getting the "This drawing has not been saved yet" error when I try to create data new data shortcuts...right after I save the drawing. The only thing I can do is close c3d and open the drawing again every time I want to create a data shortcut. Has anyone ever run across this. I create a lot of them and its just an annoyance to re start c3d all the time. Thanks
    Civil 3D 2013
    Windows 7 Professional
    i7-3930K @4.5oc
    AMD FirePro V5900
    32GB Ram
    2015-12
    Central Oregon
    591
    Default Re: Data Shortcuts - Drawing not yet saved error...
    2010-10
    24
    I am running 2013, I don't think that hotfix applies...? I think I may have solved the problem by changing my default save version back to 2013. I had it saving to 2012 for other reasons. Seems to be working so far.
    Civil 3D 2013
    i7-3930K @4.5oc
    AMD FirePro V5900
    32GB Ram
  1. 2014: Xrefing drawing that contain data shortcuts - Creates proxy objects
    By Chowdur in forum AutoCAD Civil 3D - General
    Last Post: 2014-05-20, 11:45 AM
  2. 2009: Data shortcuts and drawing pipes in profile view
    By 1971jedwards407664 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2013-01-29, 05:44 AM
  3. Replies: 0
    Last Post: 2011-10-24, 03:30 PM
  4. Data shortcuts multiple shortcuts of same alignment
    By jenniferchavez in forum AutoCAD Civil 3D - General
    Last Post: 2009-07-20, 03:28 PM
  5. Importing Data Shortcuts Error
    By shannonc.57257 in forum AutoCAD Civil 3D - General
    Last Post: 2006-12-13, 01:59 PM
Tags for this Thread
