Thread: Panel schedule problem. "Load name" not changing. Urgent!
    2015-10
    181
    Default Panel schedule problem. "Load name" not changing. Urgent!
    We recently had all the level names changed. Due to this we had to change all the panel name. I.E. BN-G5 turned into ST-G2. We changed all the panel names thinking this would change and update all the names in the panel schedules. It turns out none of the Load Name's in the panel schedules changed to the new names. What is going on here? We are pulling our hair out trying to figure out why this didn't work and what to do to get it right. Any suggestions would be awesome. Thanks
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    Default Re: Panel schedule problem. "Load name" not changing. Urgent!
    Unfortunately, the Load Name is just a text value and has no association with anything else. When you initially connect a load to a Panel, Revit will attempt to supply an appropriate name as a default, but that's all it is - a default value.
    2015-11
    Saint Louis, MO
    485
    you can highlight the load name in a panel schedule and hit update names, but i think it's a dangerous button, anything you've typed in any load name will be lost and replaced with a new "while creating it" revit name. it Does work if you've left them reading "receptacles rooms 1,3,4" and just need to add or remove some room numbers though.
    hth
    mike
  1. "Actual Lighting Load" Schedule
    By wags5116 in forum Revit MEP - General
    Last Post: 2015-05-13, 01:19 PM
  2. Changing the "Line1", "Line2", etc headers in the Project description dialog box?
    By brynjolfur853743 in forum AutoCAD Electrical - General
    Last Post: 2013-04-15, 08:25 PM
  3. how to edit "Mfg./Type" in panel schedule
    By cookie in forum Revit MEP - General
    Last Post: 2010-06-09, 12:41 PM
  4. Verification fails: "linear load has not been applied to a panel"
    By smm.144 in forum Robot Structural Analysis
    Last Post: 2010-06-08, 08:14 AM
  5. Replies: 10
    Last Post: 2010-03-11, 12:49 PM
