Results 1 to 1 of 1
Thread: Angles & Translation
    2012-06
    23
    Default Angles & Translation
    Hello All,
    Thank you in advance. Sorry I don't speak Deutsch, but if someone can help me/direct me to the proper area I'll appreciate it.
    I am re-drawing a drawing from a PDF to AutoCad2009. These drawings were create in German w/ ISO 2768-1. My 2 questions are as follows, please refer the attachments for clarity.
    #1. On drawing "Angle Confusion" it shows a dimension that has me stumped as far as the angle of the line shown. It shows the dim of (metric) 0.15 x 45 deg. Look at checking the line angularity this is not 45 deg. If someone can help me figure this one out, thank you much. Or am I over-thinking this and just use the dim shown for the machinist to use?
    #2. On drawing "Angle Translation". Can someone please translate what is shown. I did do some translation word by word but it doesn't click in my head what exactly the info is on this dim. Also, as above question it also shows that dim with the 45 deg
    Can't wait for an answer, I'm in dire need of sending these drawings out to get parts made.
    Best Regards
    KenJ
    Best Regards & Thank You
    KenJG
    AutoCad 2009 & 2014
  1. Angles & Translation
    By svr_kjg705384 in forum AutoCAD General
    Last Post: 2012-11-27, 03:14 PM
  2. Joining Channels to Angles sends components skewing at odd angles. (REVIT Struct 2012)
    By Melissa.Stewart1980 in forum Revit Structure - General
    Last Post: 2012-05-25, 05:56 PM
  3. Translation
    By chrisr in forum AutoCAD General
    Last Post: 2012-04-12, 08:49 PM
  4. Change angles of Mtext to new Angles
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2009-01-30, 07:03 AM
  5. CUI Translation
    By Ehsan in forum AutoCAD CUI Menus
    Last Post: 2007-06-25, 01:21 PM
