Does any know of a lisp that will insert one block multiple times at the mid point of every line in a drawing. (for example)
I have a lisp that insert blocks at the end point of every line in a drawing.
Maybe it can help you.
Thank you Lee Mac.
File Attached
PtManagerV2-4.lsp
Could it be changed to midpoint? I would like to check it out. Thanks Billy
Here an alternative code.
I tried to to keep it simple and not combine to many commands to make it easy to follow along.
You can also modify the program to add multiple lines to a selection set and then do the insert instead of one at a time.
HTHCode:;;; BLI.lsp ;;; ;;; Purpose: To insert a block on a midpoint of a line. (defun C:BLI () (setq ENT NIL) (setq PIC_ENT NIL) (setq BLOCK_TO_INSERT "C:\Users\Owner\Desktop\CROQUI\ST.dwg"); insert the path where your block is (setq BSCALEFACTOR 0.5) (while (null ENT) (setq PIC_ENT (entsel "\n Select Line To Insert Block To: ")) (if (= PIC_ENT NIL) (progn (princ) (exit) ) ) (setq ENT (entget (car PIC_ENT))) (if (= "LINE" (cdr (assoc 0 ENT))) (progn (setq PT1 (cdr (assoc 10 ENT))) ; get start point of line (setq PT2 (cdr (assoc 11 ENT))) ; get endpoint of line (setq RANGLE (angle PT1 PT2)) ; get angle of line (setq DANGLE (RTD RANGLE)) ; convert angle radians to deg (setq LLINE (distance PT1 PT2)) ; gets length of line (setq HOFLINE (/ LLINE 2)) ; lengh of line divided by 2 (setq INSERTPT (polar PT1 RANGLE HOFLINE)) ; set block insertion point (command "-insert" "ST" INSERTPT BSCALEFACTOR BSCALEFACTOR DANGLE ); the name of your block (setq ENT NIL) (setq PIC_ENT NIL) ) (progn (princ "\n *** You need to select a line! ") (setq ENT NIL) ) ) ) ) ;;; RTD ;;; --- ;;; Convert radians to degrees (defun RTD (A) (* A (/ 180 pi))) (princ "\n BLI.slp loaded! Type BLI to start!") (princ)
lol,,,,Im still trying to understand how to make the first lisp work correctly.
Ive got the block inserting to all points in the drawing but still looking for a way to get it to go to end points of lines. Ill check out this other lisp in a min. thanks for all your help billy.
Try this ...
Code:(defun c:Mins (/ name ss i e) (if (and (or (/= (setq name (getstring t "\n Specify Block name :")) "") (/= name nil) ) (if (not (tblsearch "BLOCK" name)) (progn (alert " name of Block is not found !!") nil ) t ) (progn (prompt "\n Select lines ...") (setq ss (ssget '((0 . "LINE")))) ) ) (repeat (setq i (sslength ss)) (setq e (entget (ssname ss (setq i (1- i))))) (entmakex (list '(0 . "INSERT") (cons 10 (mapcar (function (lambda (q p) (/ (+ q p) 2.))) (cdr (assoc 10 e)) (cdr (assoc 11 e)) ) ) (cons 2 name) '(41 . 1.0) '(42 . 1.0) '(43 . 1.0) ) ) ) (princ) ) (princ) )
lol,,,,that is cool tharwat!!! The only thing that could make that lisp better is if the block would align with the line. thank you
Like this .... ?
Code:(defun c:Mins (/ name ss i e p1 p2) (if (and (or (/= (setq name (getstring t "\n Specify Block name :")) "") (/= name nil) ) (if (not (tblsearch "BLOCK" name)) (progn (alert " name of Block is not found !!") nil ) t ) (progn (prompt "\n Select lines ...") (setq ss (ssget '((0 . "LINE")))) ) ) (repeat (setq i (sslength ss)) (setq e (entget (ssname ss (setq i (1- i))))) (entmakex (list '(0 . "INSERT") (cons 10 (mapcar (function (lambda (q p) (/ (+ q p) 2.))) (setq p1 (cdr (assoc 10 e))) (setq p2 (cdr (assoc 11 e))) ) ) (cons 2 name) (cons 50 (angle p1 p2)) '(41 . 1.0) '(42 . 1.0) '(43 . 1.0) ) ) ) (princ) ) (princ) )
That is bad a**. lol Very cool. I wish I could write lisps like that. I will have to watch how I draw my lines so the block will rotate the correct direction. Again very cool lisp. thank you
