Thread: LT2011 will not open
    2011-03
    3
    Default LT2011 will not open
    For no apparent reason, AutoCAD LT 2011 will no longer open on my PC. It worked fine until a week or so back but now when I try to run LT2011 the logo displays which changes to a grey screen which then disappears and I am left back at Windows desk top!
    My PC is running Windows 7 Home.
    Any help would be much appreciated.
    I could stop if I wanted to pendean's Avatar
    2001-12
    Dallas, TX
    228
    Default Re: LT2011 will not open
    Use Windows Restore back to a week or month it all worked and see if that helps.
    Dean Saadallah
    AutoCAD and LT User
    BLOG|TW|FB|PIN
    2011-03
    3
    Thanks for the suggestion. I have already tried restore, but without success using the earliest (longest ago) restore date.
    2011-03
    3
    I should also say that I have tried repair and reinstall options but the issue remains the same. I'm guesssing that either a windows update or some other software change has reacted and caused the problem but I have no idea what!
    All AUGI, all the time clshade's Avatar
    2009-01
    B5
    544
    Have you tried a repair install?
    Charles Shade AutoCAD LT 2014, Dynamic Blocks
    www.cshadedesign.com
  1. Replies: 3
    Last Post: 2012-06-17, 09:42 PM
  2. 2011: LT2011:ファイルを選択ダイアログ
    By tanakaiz352431 in forum 日本語 - AutoCAD
    Last Post: 2011-08-29, 05:30 AM
  3. Worksharing Monitor fails to open when Chrome open.
    By brandon.stanley in forum Revit MEP - General
    Last Post: 2011-06-16, 03:08 PM
  4. Can't open a detached version of Central with local open??
    Last Post: 2010-06-03, 01:59 PM
  5. Replies: 4
    Last Post: 2007-01-03, 04:09 PM
