wes347614
Concerning the BREAK command in AutoCAD 13LT, according to the help manual, "The prompts that are displayed next depend on how you select the object. If you select the object by using your pointing device, the program both selects the object and treats the selection point as the first break point. At the next prompt, you can continue by specifying the second point or overriding the first point."
My question is this - why treat the first place where the object is selected as the first break point? I ALWAYS have to override that and specify the first break point, which adds another step and makes the process slower. You can't snap to the first place where you want the line to be broken when you're selecting the object. I want to change the command so that I'm prompted to select the object and then automatically specify the first break point
