Thread: Different earth volumes
    2012-12
    Default Different earth volumes
    Greetings to all...
    I need some help. I am currently calculating the amount of earth removed from a land site. Using the LDT composite method I get 53.996 cu.mts. of cut, but if I use the sections method the amount increases to 67.003 cu.mts. of cut. Does anyone know why this happens?
    This puzzles me, because I cannot explain it either to my boss or to our inspector, and I have been using this software since the Softdesk ages!
    2012-07
    Default Re: Different earth volumes
    The LDT composite is the most precise cause Civil uses it's own criteria to calculate masses while other methods use the old way.
  1. 2014: Net volumes don't sum
    By trevor.hatch597223 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2014-07-03, 03:09 AM
  2. google earth connection - globe link vs google earth extension
    By rpict in forum Revit Architecture - General
    Last Post: 2010-06-21, 03:27 PM
  3. Avatech Earth Connector for Google Earth
    By Tobie in forum Revit Architecture - General
    Last Post: 2006-07-11, 12:47 PM
  4. Earth Connector for Google Earth ( freeware )
    By Mike.Perry in forum AutoCAD General
    Last Post: 2006-01-06, 12:22 PM
