Hi All,
I was working with ilogic, Adding a new rule and all of a sudden I got an error and when I double click on a parameter to add it to the code, the format changed.
It used to look like this when I added a parameter: Parameter("vertical seperation:1", "partitionthickness")
but now when I double click on a parameter I get this: vertical seperation.ipt.partitionthickness
Also when I right click on a parameter and select display current state, It does the same thing, for some reason the code does not display like it used to.
Could anyone please tell me what is wrong, I got an error when this first happened and I tried reproduce the error again but it did not appear again. This affected all my parts and even in different projects.
I re installed inventor because I thought there might be a file link broken but it did not fix it.
Thanks.
