Thread: ABC conduit
    2008-11
    27
    Default ABC conduit
    this is my 1st post in MEP, and my first day to use Revit MEP, why when i draw conduits, the fitting don't get the same size. see attached
    New Document.pdf
    2015-11
    Saint Louis, MO
    484
    Default Re: ABC conduit
    there is a lookup table that goes along with each fitting family, it is a separate file with a similar name as the family. check your revit.ini file for the location it is using for lookup tables, and change it to where your family library content folder is installed.
    hope that helps,
    mike
  1. different conduit colors
    By Ning Zhou in forum Revit MEP - General
    Last Post: 2011-09-30, 03:23 PM
  2. BOM for conduit
    By JAR-QE in forum ACA/AMEP Tips & Tricks
    Last Post: 2011-04-18, 09:45 PM
  3. 2011: Conduit Property Set
    By trent.chambers in forum AMEP General
    Last Post: 2010-10-27, 05:54 AM
  4. 2011 Conduit
    By wags5116 in forum Revit MEP - General
    Last Post: 2010-09-29, 04:57 AM
  5. PVC Conduit
    By ltuss in forum Revit MEP - Families
    Last Post: 2009-04-13, 12:47 PM
