Results 1 to 6 of 6
Thread: Revolving Door in Curtain Wall
    2005-01
    12
    Default Revolving Door in Curtain Wall
    I've searched around, but haven't been able to find a solution to placing an all glass revolving door in a curtain wall ( or any revolving door for that matter). Is there something I'm missing?
    Thanks in advance!
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Re: Revolving Door in Curtain Wall
    All I know is that a revolving door to be in a curtain wall starts to defeat the idea of a curtain wall. You will have to be creative in coming up with a solution. there are revolving doors that you can use, and maybe they have been created for a wall, and not a 3d object. But, I think you can create your own revolving door for a curtain wall (which is actually a Curtain Wall Panel), since I have seen a curved curtain wall panel.....but I have never tried to create my own panel before, and don't know if there are some issues for doing such a 3d panel....
    Good luck!!!
    Peace,
    2003-05
    5,153
    You could try making the curtain panel where the door is to go a solid panel, ( to the width of the door required ) then convert it to a solid wall type and then place a revolving door in that wall.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    2015-11
    Royal oak, Michigan
    1,513
    Way to go Beege, you are quite quick to think of a workaround using new 7.0 features.....sounds like it will work perfectly!!!!
    I could stop if I wanted to Tom Dorner's Avatar
    2003-11
    Phoenix, AZ
    371
    There is one posted at www.revitcity.com that is made to be inserted as a curtain wall panel. It is under 'doors' 'specialty'
    Tom
    2005-01
    12
    Thanks - the one at revcity wasn't working, so I created a wall type for where I wanted the revolver to go - and it went in fine.
    thanks for the help.
  1. Revolving curtain wall door
    By Rodger in forum Revit Architecture - Families
    Last Post: 2012-05-25, 09:05 PM
  2. Revolving Door for Curtain Walls
    By phyllisr in forum Revit Architecture - Families
    Last Post: 2011-06-27, 05:11 PM
  3. I wish I was able to add a door in a curtain wall without having to size the curtain wall grid.
    Last Post: 2008-01-11, 04:14 PM
  4. Revolving door for curtain panel?
    By neels in forum Revit Architecture - General
    Last Post: 2005-03-23, 08:51 AM
  5. Revolving Door?
    By Jarod in forum Revit Architecture - General
    Last Post: 2005-02-04, 10:42 PM
