Results 1 to 10 of 10
Thread: xref list extraction
    2012-11
    Brisbane, Australia
    239
    Default xref list extraction
    Hey all
    I am trying to find a way of extracting a list of all the xref names from a drawing but so far i have had no luck. does anyone know how to achieve this?
    2010-10
    535
    Default Re: xref list extraction
    Quote Originally Posted by matthew.e.mortimer342462 View Post
    Hey all
    perhaps
    (defun FindXref (/ blk lst)
          (while (setq blk (tblnext "block" (not blk)))
                (if (= 4
                       (logand 4
                               (cdr (assoc 70
                                           (tblsearch
                                                 "BLOCK"
                                                 (setq bn (cdr (assoc 2 blk)))
                      (setq lst (cons bn lst))
          lst
    2010-06
    962
    Another with Vla functions .
    (defun XrefList (/ lst)
      (vl-load-com)
      (vlax-for block (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
        (if (eq :vlax-true (vla-get-IsXref block))
          (setq lst (cons (vla-get-name block) lst))
      lst
    2012-11
    Brisbane, Australia
    239
    Cheers Fellas, i didnt think about approaching the problem this way i was looking for a system variable or command, does such way not existing?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Check out the Express Tool Propulate. From the Menu Express => File tools => Update Drawing Property Data. The default will add a list of loaded Xrefs and Fonts to the Comments section of the Summary tab of Drawing Properties. You can customize it however you like. The File tools are only in the Menu not in the Ribbon in 2012.
    2012-11
    Brisbane, Australia
    239
    Cheers mate, ive never seen that tool before. it looks interesting but all i can seem to do with it is update my drawing from the used template. maybe im doing it wrong.
    these are my steps:
    PROPULATE
    Update
    Current
    ive tried a few other combinations bit they all seem to relate specifically to the template.
    2001-03
    Tallahassee, FL USA
    3,667
    these are my steps:
    PROPULATE
    Update
    Current
    Enter _dwgprops at the command line, found in the File menu as Drawing Properties. In the dialog box that comes up on the Comments section of the Summary tab should be a list of loaded Xrefs, Fonts and Images. If not you may have to Edit the Propulate Template and run it again. In the Comments section make sure you have => @[XREFLIST] @[FONTLIST] @[IMAGELIST]
    That puts the lists in the Drawing Properties when you update the current drawing. Been a while, but I thought it was in the default template. I have my self as the Author and a handful of Custom properties which are referenced with fields in all my layouts such as the number of pages so that if another page is added to the set it only has to be updated in Drawing Properties instead of on every sheet.
    2012-11
    Brisbane, Australia
    239
    thats pretty cool mate, i dont suppose there is a way of extracting that data into lisp?
    2001-03
    Tallahassee, FL USA
    3,667
    Once it's been added to Drawing Properties sure:
    http://forums.augi.com/showthread.ph...o-they-mix-!#3
    2015-11
    Highlands ranch, CO
    29
    I found the attached routine that lists XREFs both attached and overlayed and poops out a .txt file that lists the Xrefs.
    Can be found here as well: http://forums.autodesk.com/t5/Visual...t/true#M292314
    XrefTree.lsp
    ~Greg
  1. XREF Manager to list if xrefs are attached to another Xref
    Last Post: 2014-10-28, 04:13 AM
  2. Add handleID or entity properties to data extraction tool selections list
    Last Post: 2014-05-09, 09:32 PM
  3. 2014: List a layer in Xref
    By nextvkin in forum AutoCAD LT - General
    Last Post: 2013-09-18, 04:30 PM
  4. Xref List to Dialog Box
    By fletch97 in forum AutoLISP
    Last Post: 2009-09-03, 02:22 AM
  5. 2008 SCALE 1:100 xref xref xref xref- scale list issues
    By Apsis0215 in forum AutoCAD Customization
    Last Post: 2008-11-21, 08:17 PM
