Thread: Fonts Not Showing in Text Style Box
    2004-06
    5
    Default Fonts Not Showing in Text Style Box
    I have recently copied several .shx files to the default Fonts folder referenced by the Support File Search Path but they do not show up in the Text Style dialog box. I have restarted ACAD a couple times and even re-booted my computer. Any suggestions?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,685
    Default Re: Fonts Not Showing in Text Style Box
    Probably shape files which have the same extension. Do they show up as fonts on another computer?
    100 Club heinsite's Avatar
    2005-11
    Kona, Hawaii
    138
    One very strange behavior I saw once was that AutoCAD would *not* see font files if they had been compressed. This will happen if you do a Disk Cleanup operation and the fonts get compressed. They'll show up in the explorer as blue files in the listing. It's one more thing to check.
    Dave.
    Earth
    9,821
    Quote Originally Posted by khworley View Post
    One way to test is to use the LOAD command in AutoCAD.
    Pick the SHX file.
    If it is a font file, you will get this message: "xxxx.SHX is a normal text font file, not a shape file."
    Otherwise it will load the selected .shx file and you'll know it's a "shape" file, not a font.
    R.K. McSwain | CAD Panacea |
  1. 2015: Probleme with text fonts
    By erik701494 in forum Revit Architecture - General
    Last Post: 2015-05-28, 08:08 PM
  2. Isolate Selected Text Style or Dim Style
    Last Post: 2013-01-20, 05:10 AM
  3. Replies: 2
    Last Post: 2009-07-15, 07:07 PM
  4. Revit and true-style fonts
    By Matt Mercer in forum Revit Architecture - General
    Last Post: 2007-01-04, 07:42 PM
  5. Different fonts have started showing up as default AutoCAD fonts
    By jackie.112886 in forum AutoCAD General
    Last Post: 2006-05-15, 11:02 PM
