I am having an issue where elevation tags aren't behaving as expected when views are set up with true north versus project north. The background is that we got 60% of the way complete with the project and then someone decided all views needed to be displayed at the true north orientation not project north. When trying to rotate one or the other, we had issues with a lot of errors, deleted elements, etc. So we ended up displaying all views as true north and just ignored the project north setting.
Now, all of my elevation tags show the sheet number on top and the detail number on the bottom, because they are in effect rotated 180 degrees. The only solution I could come up with was creating a custom elevation tag family which actually switches the two labels to be opposite of typical so they will work on this project. Can you think of anything else I might be missing?
