Thread: converting multi sheet drawing file into single drawing files
    2007-05
    2
    Default converting multi sheet drawing file into single drawing files
    Hi all,
    We have a client that requires each drawing sheet as a separate file. The problem is our office only produces multi sheet (as in multiple layout) drawing files. I am looking for a solution that allows me to convert the multisheet drawing into multiple files.
    I already went the route of publishing to single sheet pdf, converting the pdf files into dxf files and then saving them again as dwg files. This method is very labor intensive and does not yield good results.
    Has anyone run across a similar situation before? Maybe someone has developed a lisp or script?
    2001-12
    St. Louis
    5,408
    Default Re: converting multi sheet drawing file into single drawing files
    Quote Originally Posted by harryschoenauer View Post
    Hi all,
    Have you tried the EXPORTLAYOUT command?
    (I'm not sure which release of AutoCAD added that command, but, it's been around a few releases now, which version are you using?)
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2007-05
    2
    Great Tip!
    We are using 2010 to 2013. It seems to work great, but is still a little labour intensive with drawings that have a lot of layouts (50+).
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Try the AutoLISP routine found on this website.
  1. Replies: 4
    Last Post: 2013-11-17, 09:49 PM
  2. Replies: 0
    Last Post: 2012-11-24, 07:38 PM
  3. Drawing Multi-Sheet open and edit
    Last Post: 2007-06-22, 04:32 PM
  4. Replies: 2
    Last Post: 2006-05-02, 04:41 PM
