Thread: My parts will fully constrain but wont let me extrude the object if I use seperate lines.
    Angry My parts will fully constrain but wont let me extrude the object if I use seperate lines.
    I am drawing in inventor 2012. If I draw a circle or a rectangle it wll let me extrude, but if I draw seperate lines or
    try to add an arch it will constrain but when I go to extrude it it won't allow me too extrude the area of the object. Diagnosis says
    "Open loop found in this profile. Use Close Loop or use Edit Sketch and project geometry, add sketch geometry, and/or drag the loop endpoints to close the loop."
    and I am not sure what to do to fix it. Is it a setting I accidently turned on or off or am I skipping something somewhere.
    I am a student and have been working on this for a week and can't figure it out on myown.
    Any help would be greatly appreciated in advance thanks again !!!
    Williamsport, PA
    641
    Default Re: My parts will fully constrain but wont let me extrude the object if I use seperate lines.
    My guess is that you turned off Constraint Persistance.
    But all is guessing without the file.
    Attach the *.ipt file here and remove all doubt.
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    AU 2007 Avatech Altogether Smarter Inventor On-line Challenge 1st Place
    Autodesk Inventor Certified Expert
    Certified SolidWorks Professional
    Williamsport, PA
  1. Partial Array that trims an object if it cannot be fully used
    By avminkler in forum AutoCAD Customization
    Last Post: 2012-06-18, 08:07 PM
  2. Toggle tag anchor constrain to object
    By kevin.bell.72378 in forum ACA Wish List
    Last Post: 2009-10-28, 04:15 PM
  3. Extrude 3D object
    By erictsn in forum AutoCAD Map 3D - General
    Last Post: 2007-09-12, 05:30 PM
  4. How to show same object differently in seperate views?
    By msaroya in forum Revit Architecture - General
    Last Post: 2007-01-05, 12:56 AM
  5. Is there a way to un-extrude an object?
    By matt.bauer in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-05-02, 02:28 PM
