Thread: Change All Layers' Plot Style Setting
    2013-02
    Default Change All Layers' Plot Style Setting
    I'm trying to write some code that will
    1) set the current plot style table to "BCR Plot Style.stb"
    2) change all layer properties to plot style name "Grayscale"
    (defun c:grayscale ()
    (vl-load-com)
     (vla-put-StyleSheet
        (vla-get-ActiveLayout
      	(vla-get-ActiveDocument (vlax-get-acad-object))
        (setq layers (vla-get-layers
      (vlax-for l layers
        (progn
     	(vla-put-plotstylename l "Grayscale")
    This routine works after I go into the layer properties manager, highlight all layers, change the plot style to "Grayscale" and then back to "Normal".
    It's like it hasn't recognized "Grayscale" as a valid option until it has been manually set.
    Is there some way I can make AutoCAD "recognize" Grayscale as a valid option from the beginning?
    I feel like this would be a tblsearch or something similar, but would appreciate any suggestions.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: Change All Layers' Plot Style Setting
    Your desired plot style is not initially listed in the dictionary list. By manually changing it, AutoCAD is adding it to the list. You could change your code to use the command line version of the layer command. It allows the setting of unloaded plot styles.
  1. Batch Plot Style Change
    By OCD in forum AutoCAD Plotting
    Last Post: 2019-03-18, 04:09 PM
  2. 2012: Can I change plot style with lisp or script?
    By dolan.raynor in forum AutoCAD General
    Last Post: 2013-07-18, 01:19 PM
  3. setting the plot style
    By rstiles in forum AutoLISP
    Last Post: 2012-02-10, 07:54 PM
  4. Setting Plot Style Table in Lisp
    By fletch97 in forum AutoLISP
    Last Post: 2007-01-30, 09:43 PM
  5. CHANGE PLOT STYLE TABLE
    By eng5 in forum AutoCAD General
    Last Post: 2005-03-08, 01:09 PM
Tags for this Thread
