Thread: QTO 2013; Is anyone successfully using it?
    2012-10
    Cleveland, Ohio
    7
    Default QTO 2013; Is anyone successfully using it?
    We have had significant issues using QTO 2013. QTO constantly crashes, we see this happen when importing a Revit model as wells as a 2d pdf takeoff. In most cases, it corrupts the data file so we loose many hours of work.
    Is anyone using QTO without these problems?
    Lew Heifner
    2011-09
    Default Re: QTO 2013; Is anyone successfully using it?
    I can't even get it to load dwf files from Revit 2013. It's so bad for me that I can't get to where you are...
    2012-10
    Cleveland, Ohio
    7
    I am not convinced that anyone is using QTO 2013 problem free. We have now resorted to doing a save followed by a "save as ....01, ....02, ....etc."
    Anyway, still waiting to hear from someone who is successfully using QTO.....
    2012-10
    Cleveland, Ohio
    7
    Last Friday I had a QTO expert in our office for a troubleshoot / debug session. We were working off of local files on the c: drive.
    Is it possible the file corruption is due to a network issue and the software crashing is due to software bugs? I wonder if we are chasing problems from 2 different sources and we are looking in one direction only?
    If the network crashes are causing the corrupt files, the software should be smart enough to recover. When I have noticed the data corruption, there is no recovering from it. I have Windows Explorer open at the same time as I am working with QTO so I can view the file size. When I see a 50mb files suddenly save as a 100kb file, I know there is a problem and obviously a lot of data is missing. My initial intent was to watch the file size and then perform a "save as" to attempt to reinstate file integrity. QTO will allow the "save as", however, any additional files are also corrupt and 100kb.
    As it stands now, I am the only person in our office using QTO and on a limited basis until we can resolve these problems. Does anyone have a suggestion as to how we can determine if the network is or is not the problem?
    2012-10
    Cleveland, Ohio
    7
    We have proved the network is not the issue. I was using QTO with local data files and experienced. the same issues.
  1. CM23-2: Successfully Budgeting and Managing Your Software
    By Autodesk University in forum CAD Management
    Last Post: 2013-04-08, 07:32 PM
  2. Share parameters - Not successfully saved
    By agustnj.187972 in forum Revit Architecture - General
    Last Post: 2009-09-02, 12:20 PM
  3. Successfully Sharing MEP PN Project with Revit
    By bradg in forum Project Navigator
    Last Post: 2009-05-05, 02:36 PM
  4. Replies: 1
    Last Post: 2007-05-09, 02:51 PM
  5. Anyone using a Quadro 3450 successfully with revit 9.1
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2006-12-04, 07:44 PM
Tags for this Thread
