Thread: Help with Shapefile export
    2011-09
    9
    Default Help with Shapefile export
    I am a basic Autocad user, by this I mean, I am self taught and know how to do what I need to which is pretty basic stuff. So please... Be gentle. Ok, a "government agency" is requiring me to submit info to them in shapefile format. Their wording.. ".... should be represented as a closed, non-overlapping polygon with the associated feature attributes...." Supposedly, there is a .prj file associated with this. In just playing around, the MapExport command can generate a .shp, but I am curious to know where does this .prj come into play and what do you think they mean by "... use an unprojected WGS84 coordinate system..." and have minimum horizontal accuracy of +/- 40 feet conforming to 1:24K national mapping standards. I do set up a WGS84 system when I bring in my county provided maps and everything is laid out to 5280 units is a mile. So I dont bug anyone to death, is there somewhere I can go and learn how to do .shp file generation and this .prj attachment??
    Turlock, CA
    6,373
    Default Re: Help with Shapefile export
    Sounds like you have everything you need. Just do the export. It will create a folder with several files in it. A "shape file" is really several files, prj (the projection) being one of them.
    C:> ED WORKING....
    2011-09
    9
    Ok, that sounds great, maybe I was making a mountain of a molehill.
    2011-09
    9
    I think I have it figured out best I can. Yes, I set up coordinate system in new drawing and use a copyclip to bring in what I want from a pre-generated map. When do a map export, make sure I use the polygon selection. (this now shows me NAD83 in the options tab for the coords.) Selecting the polygon also creates the .prj file. I also found out that if you want all objects saved, not just lines, in the "save" box where you add your file name, at the bottom you can select Shape Multiclass and all objects will be saved under various names. Some of the help areas point you toward the export drop down box and appending the file. I could not easily find where that was, but did find this. Also noticed that text is not saved as readable text, just dots. Dont know how to fix that, but I found what I needed. Thanks Ed.
    TN/KY Area
    1,640
    Ah come on the gov't is not that hard to get along with, most of the agencies don't know what they want to start with and if wait long enough the person asking for it will forget or be in another position. (Yes I work for the Gov't) The text are exported as a point type and the text string is an attribute of the point. One thing you may want to make sure is when you export include the data of the objects. This can be the properties (layer, color, area, etc) or object data attached and attributes of any blocks exported.
  1. How to fix a corrupt shapefile when using AutoCAD Map?
    By GreyHippo in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2012-02-25, 12:48 AM
  2. Using lisp to Automatically export to shapefile
    By john.bendix in forum AutoLISP
    Last Post: 2010-08-26, 05:07 PM
  3. Loss of Shapefile Export
    By Matt_Drainage in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-04, 11:29 PM
  4. Export Flood Trace to shapefile
    By kevin.bell81772 in forum AutoCAD Map 3D - General
    Last Post: 2005-08-19, 03:13 PM
