Thread: Diameter symbol in Pipe Part Size Name (PrtSN) using Calculation Assistant?
    2013-02
    3
    Default Diameter symbol in Pipe Part Size Name (PrtSN) using Calculation Assistant?
    I am unable to add a Diameter symbol in the Pipe Part Size Name (PrtSN) using Calculation Assistant in Part Builder in Civil3D 2013?
    Ideally I would like to have the calculation for PrtSN place a Diameter symbol in front of the Inner Pipe Diameter (PID).
    Any help would be greatly appreciated!
    2013-02
    3
    Default Re: Diameter symbol in Pipe Part Size Name (PrtSN) using Calculation Assistant?
    I managed to add the symbol by simply Copying & Pasting from the symbols library in Microsoft Word... Unfortunately, there is still no way that I can find to omit the space though...
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,171
    Thanks for posting a follow-up.
    2024-03
    Quote Originally Posted by RDunkley View Post
    Hold down the"Alt" key and press 0216 on the number pad. Ø.
  1. 2015: Pipe Fittings - Limit Size Choice in Diameter Pulldown
    By eptownie1988 in forum Revit - API
    Last Post: 2014-09-08, 03:07 PM
  2. diameter symbol in pipe tag callout
    By ekohles in forum Revit MEP - General
    Last Post: 2014-08-20, 07:22 PM
  3. 2013: Help to change size of pipe up down symbol
    By dfolk687163 in forum Revit MEP - General
    Last Post: 2013-03-18, 01:50 PM
  4. Pipe Size and Part Number
    By cdsuggs in forum Revit MEP - General
    Last Post: 2010-06-22, 09:50 PM
  5. Is there a way to change the Pipe drop symbol size?
    By NATHAN46290 in forum Revit MEP - General
    Last Post: 2009-07-27, 11:00 PM
Tags for this Thread
