Thread: Deleting toolbars from a .cuix
    2008-07
    Boise
    63
    Default Deleting toolbars from a .cuix
    I have what I think is a simple question, but I am having difficulty with it. I have a company .cuix menu that is loaded as a partial menu to the main acad.cuix file. I want to delete all the toolbars and pull down menus associated with it and leave the other stuff in place. This is in Autocad 2011 but should also translate to 2013. So far, I have tried opening the CUI menu, going to the company.cuix partial menu and deleting the toolbars. Then I hit save, then Apply. Toolbars disappear and pulldown menus go away. But when I reload AutoCAD they come back. What am I missing here?
    0,0,0 The Origin
    8,570
    Default Re: Deleting toolbars from a .cuix
    Are you absolutely certain that the file you are editing is the same one as is being opened by acad?
    Turlock, CA
    6,003
    You say its company cuix. Is it getting reloaded from a network location each session? Perhaps from a startup switch, profile?
    C:> ED WORKING....
    2009-11
    5,667
    Sounds like their startup checks for differences in a local copy of the company CUIx, and if the modify dates are different the company one overrides.
    Is it not possible to instead simply modify your workspace, rather than attempting to modify/delete components from the company CUIx? If your company mandates something, methinks attempting to permanently delete are not going to be well received.
    Computer Specs:
  1. MNL not loading with CUIx
    By nbittner673091 in forum ACA General
    Last Post: 2012-04-04, 12:02 AM
  2. Can you save a CUIx as a CUI?
    By g.doyle in forum AutoCAD CUI Menus
    Last Post: 2010-10-14, 12:58 AM
  3. Company CUIX
    By thomas.stright in forum AutoCAD CUI Menus
    Last Post: 2010-06-03, 10:54 PM
  4. Missing pdfic.cuix pdfmacad.cuix
    By kathleen.143968 in forum AutoCAD CUI Menus
    Last Post: 2010-02-01, 10:51 PM
  5. No Menus or Toolbars in ACA.cuix?!?
    By bowlingbrad in forum AutoCAD CUI Menus
    Last Post: 2009-09-08, 08:32 PM
