Thread: layer control drop down does not show the layer of selected objects
    2013-02
    Default layer control drop down does not show the layer of selected objects
    When I need to know the layer of an object I just click on it and glance at the Layer Control field. I am new to 2012, but with 2007 this always showed the layer of the selection. I see on other 2012 users that it works this way for them, but mine always just shows the current layer. Is there a switch or setting that I need to change? FYI I'm using 2012 in "Autocad classic" view mode.
    2001-12
    St. Louis
    5,416
    Default Re: layer control drop down does not show the layer of selected objects
    Quote Originally Posted by dleversen360181 View Post
    Is your PICKFIRST system variable set to 1?
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Layer Control drop down not working
    By panfishbandit in forum AutoCAD Mechanical - General
    Last Post: 2015-10-08, 04:53 AM
  2. 2015: Layer Control Drop-Down Issue
    By jledgewood in forum AutoCAD General
    Last Post: 2015-01-28, 05:25 PM
  3. Layer filter for currently selected objects in layer properties palette
    Last Post: 2010-06-09, 01:16 PM
  4. Layer control drop down problem
    By kimlance in forum AutoCAD General
    Last Post: 2010-04-30, 08:25 PM
  5. Replies: 3
    Last Post: 2007-03-14, 01:33 PM
