Results 1 to 1 of 1
Thread: Pesky trusses!
    2012-07
    26
    Default Pesky trusses!
    Firstly, I have totally given up on the Revit truss tool and have made up my truss from beams and columns, this looks great as I can use the cope tool to trim the ends of the beam etc. BUT i have 2 problems;
    1. I have created my truss in a seperate project as I thought this would be simpler but am now struggling to transfer it into my 'actual' project. I have tried 'load as group into open projects' but it messes up the alignment of the members. What would be the best way to get it into my project?
    2. I am trying to create a series of trusses where the end bay of the truss varies on each one. Can anybody suggest how I would achieve this? I know I need a new parameter but cant seem to get the beams to constrain so that when I update the domension, the sloping beam moves to accomodate the new dim. In the attached image I need dimension (a) to change when the overall dimension is updated.
    I have attached the project containing the truss.
    Any help would be much appreciated.
  1. 2011: pesky radius
    By fwaldropii in forum Revit Architecture - Families
    Last Post: 2011-07-08, 06:43 PM
  2. Pesky hatch draworder...
    By d_lay123 in forum AutoLISP
    Last Post: 2008-06-09, 09:12 PM
  3. Help reassigning that pesky F1 key
    By BrenBren in forum AutoCAD FAQ (Read only)
    Last Post: 2006-08-31, 01:06 PM
  4. Pesky Beam Ends
    By BunyipCatcher in forum Revit Architecture - General
    Last Post: 2006-02-09, 06:01 PM
  5. Pesky Wall Intersections
    By Dean Camlin in forum Revit Architecture - Tips & Tricks
    Last Post: 2003-05-15, 02:53 PM
Tags for this Thread
