Hi - Does anyone know why my layout and view port are not plotting the lines correctly? For example, my hidden lines and coming out as solid lines.
Something to try, check what your settings are for
psltscale (I set mine to 1)
msltscale - as above
cannoscale - set to the same as your vport scale i. 1:100
ltscale - this one you might have to try different settings. Start with 1 then if the line still look solid rather than hidden maybe .5
There are I'm sure other settings as well & the wiser folk here will be able to point you in the right direction. Not sure if this is the "proper way" but usually works for me.
ltscale worked on paper space at the layout tab! Thanks
However, when I go model space ..... the line weights are wrong. I had to set it back to .960000.
Any suggestion on both coordinating?
Are you familiar with annotative scaling?
(there should be a demo video available here: youtube sorry, I can't get to youtube from here to pick a specific one)
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
Been struggling with 3d solids not displaying correctly in viewports, and specifically not printing correctly either. It turned out to be numerous settings. I've been at this for two days, so was relieved to find this:
Among the setting are;
DISPSILH: 1
INTERSECTIONDISPLAY: 1
HIDEPRECISION: 1
You will need to peruse the article to get the others...but finally IT WORKED. Hope this helps someone.
