Thread: Navisworks Transfor Move or Rotate - Does not Track changes
    2006-02
    5
    Default Navisworks Transfor Move or Rotate - Does not Track changes
    Does any one knows how to change my settings to keep track when I move or Rotate an object with the Move or rotate transform.
    When I use Navis 2011 or 2012 any object moved could be verified later what changes where done in position. Now with 2013, I move an object and then instantly loses track of how much I moved.
    Please let me know which settings should I change so I get to see those changes again.
    I could stop if I wanted to brenehan's Avatar
    2007-02
    Melbourne
    226
    Default Re: Navisworks Transfor Move or Rotate - Does not Track changes
    Hi Revit Tunes
    I do believe i have seen this happening.
    Be aware there is a diference between the "transform" tool and the "move" tool.
    I believe the transform tool "may" (just double check that) track the change.
    I only use the move tool for short temporary changes. That is, if i move elemen x by y mm's will that resolve the clashes?
    I'm not sure if that helps?
    Brian Renehan
    BIM Consultant
    Melbourne - Australia
    http://bimfix.blogspot.com
    2006-02
    5
    Not, I don not help at all
    Besides, move is a transform
  1. Quick rotate and / or move-rotate
    By Rroger_D in forum AutoLISP
    Last Post: 2015-08-13, 09:22 PM
  2. Cannot see Objects as I move or rotate them
    By chrisr in forum AutoCAD General
    Last Post: 2010-07-19, 12:49 PM
  3. Copy/Move/Rotate
    By joshua.harter in forum ACA General
    Last Post: 2010-01-28, 08:58 PM
  4. rotate then move
    By chad.beussink in forum AutoLISP
    Last Post: 2008-08-22, 01:23 PM
  5. Can not see Objects as I Move them or Rotate them
    By hugvi76 in forum AutoCAD General
    Last Post: 2005-01-19, 10:04 PM
