Thread: Ability to put object parameters/data in text
    Wish List Administration
    2011-08
    4,581
    Default Ability to put object parameters/data in text
    Summary: Ability to put object parameters/data from user selected objects in text. Almost like fields in MS Office Word.
    Description: It sure would had solved a lot off issues if we could put object data/ parameters in text when tags don't cover our needs. Since the data/ parameters automatically will update when changes is made to de object, the user will always stay true to the system. It is also possible to fetch data/ parametes from different objects.
    This is almost similiar to fields in Word.
    Example of functionality and usage: When in text editor click "fetch object data/ parameter"-button, then click the object, and then choose the parameter/ data.
    Example text (object data/ patameters in clams): "[Concrete] floor [B40], depth [220mm], area [1000m2] at bottom elevation [+10,72] with [ceramic tiles] finish"
    Product and Feature: Revit Architecture - Annotation Tools
    Submitted By: Øystein Molnes on 03/06/2013
    2011-08
    4,581
    Exclamation Re: Ability to put object parameters/data in text
  1. 2014: Added object data fields to Polyline, but object data is empty or zero
    By tntdraftsol in forum AutoCAD Map 3D - General
    Last Post: 2015-07-24, 12:20 PM
  2. Ability to Delete Parameters Multiple Parameters
    Last Post: 2008-08-18, 04:40 PM
  3. Export Object data to a text file?
    By rob.fryer in forum AutoLISP
    Last Post: 2007-02-20, 01:58 PM
  4. Object Data to Text Label
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-09-20, 07:11 AM
  5. text object data
    By roy.70844 in forum AutoCAD Map 3D - General
    Last Post: 2006-06-08, 10:23 AM
