Results 1 to 7 of 7
Thread: Mouldings on Exterior Arches
    2015-08
    Jacksonville, Fl
    274
    Default Mouldings on Exterior Arches
    I have a single family res with 9 different exterior arches which I want to provide a raised stucco band over. My first approach is to make separate in place families for each arch. Is there a better way using any type of family in lieu of in place family?
    2002-02
    St. Louis, MO
    4,695
    Default Re: Mouldings on Exterior Arches
    A. Make a generic wall based family.
    B. Build it into the window or door family.
    C. Nest a generic family inside the window/door family.
    2015-08
    Jacksonville, Fl
    274
    In this situation the arches are open under (ie porches and entries.)
    However thank you for my next question with the arch windows and doors.
    2002-02
    St. Louis, MO
    4,695
    In that case.
    A. ..from above.
    B. Edit profile of the wall.
    2015-08
    Jacksonville, Fl
    274
    Sorry, went away for a long weekend.
    I know how to edit the profile of a wall and that will give me the arch. What I want to do is put a raised stucco band over the arches.
    2003-05
    5,153
    Its quite fast to just add a thicker wall, set to stucco material, and edit its profile, join geometry, to create a "stucco band effect "
    Quote Originally Posted by pwmsmith
    All AUGI, all the time BomberAIA's Avatar
    2003-05
    Boca Raton, FL
    652
    I add an in place sweep w/ a profile from Fypon or Foam Factory to the family. It's really fast.
  1. Exterior bands and mouldings
    By cadmaster77 in forum Revit Architecture - General
    Last Post: 2010-06-16, 07:40 PM
  2. Fg samples & mouldings
    By durass in forum 3ds Max - mental ray
    Last Post: 2010-02-24, 08:21 PM
  3. Brick Arches
    By BCrouse in forum ACA Wish List
    Last Post: 2005-10-13, 06:55 PM
  4. Brick Jack Arches and Arches
    By BCrouse in forum AutoLISP
    Last Post: 2005-08-16, 08:27 PM
  5. Brick Arches and Jack Arches
    Last Post: 2004-06-03, 09:51 PM
