I am setting up switches for the opening target in the Properties Shortcut in order to open a dwt file from SSM. I can get SSM to open and populate but I want the dwt file to open and ask to be saved as a project dwg file. How then do I get just the dwt file to populate the SSM after being saved as a dwg project as a dwg file? The individual projects are saved in various other folder locations based on several differing criteria. As I understand SSM it takes a dst file in order for the SSM to open a folder. When that happens is, there are now more files available in the SSM that I do not want available. Also when I save the dwt file, while it is in the SSM it does not ask to be saved as, like when a dwt file does when it is opened without SSM. I hope I have explained this well enough to get the help I need. Please advise. Thank you!
