Thread: Part Builder
    2006-10
    Durango, Mexico
    127
    Default Part Builder
    Hi
    Anyone knows about a good tutorial/manual for a pipe/structure part builder in civil 3d?
    Thanks in advance
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,135
    Default Re: Part Builder
    Not really. You might look in the AU courses from the past to see if there is something that will work for you.
    Otherwise, you might try magic. That is about all that has ever worked for me.
    2011-02
    I have not found a good tutorial. I think that I went through this in 2008/2009 with the Autodesk tutorial. I did gain some understanding of drawing from scratch. What I have had success with is to start with a part that is similar in size and type to what I need and then to adjust the parameters to fit the standard structure that I need. Some of the parameters are constants, some calculations and some can come from list. I also can rename it to the structure standard and then save it as a new part family. I recommend that you back up your default catalog before you start so you can restore it if it gets corrupted.
    2008-03
    Columbia/Jefferson City, MO
    224
    Like Opie said the AU courses may be your best bet. Here is a link to a AU 2011 class that Eric Chappell did on creating cutom storm inlets: http://au.autodesk.com/?nd=class&session_id=9384
    I have tried wading into those part builder waters and they are not kind.
  1. CV218-4: Get the Part: AutoCAD Civil 3D Part Builder
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 04:52 AM
  2. 2011: Part Builder/Catalog
    By Michael Anderson in forum AutoCAD Civil 3D - Pipes
    Last Post: 2011-09-15, 12:09 PM
  3. Part Builder Parameters
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2010-11-20, 01:01 PM
  4. Part Builder
    By a.navarrete in forum AutoCAD Civil 3D - General
    Last Post: 2009-04-16, 02:33 PM
  5. part builder
    By wag24 in forum AutoCAD Civil 3D - General
    Last Post: 2008-08-06, 10:14 PM
