Thread: Always used LDD and C3D...Now on AutoCAD2012. How do I do a bearing and distance line table?
    2013-03
    Default Always used LDD and C3D...Now on AutoCAD2012. How do I do a bearing and distance line table?
    I'm lost, I don't have any of my Civil add-ons or survey stuff. I am now working at a very small company...me and the engineer. We do Civil Site Design. But we only have AutoCAD 2012. I have used LDD and C3D for years before this. Long story short, we are doing a favor for a surveyor, and I am working on a wetlands map that has 1000 or more deliniation lines that need labled and I need to create a bearing and distance line table for them. Normally, this would be a few clicks and about 5-10 mins of cleanup work. But I can't figure out if its even possible now with the basic program. Any ideas, or lisp routines that would work for this platform? Thanks everyone!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,681
    Default Re: Always used LDD and C3D...Now on AutoCAD2012. How do I do a bearing and distance line table?
    There are probably some AutoLISP routines out there to help. Otherwise, it will not be a quick and easy task.
    You might be able to create a dynamic block to display the bearing and distance between two points.
    Earth
    9,802
    Quote Originally Posted by nate.evans79366070 View Post
    Take a look at http://dotsoft.com/mapworks.htm and/or http://www.carlsonsw.com
    If this is a one time deal, get a Carlson demo and use it (it is good for so many commands, plenty enough to run a line table)
    R.K. McSwain | CAD Panacea |
  1. Replies: 6
    Last Post: 2014-10-16, 08:27 PM
  2. Annotate bearing/distance
    By justinxxvii in forum AutoCAD General
    Last Post: 2009-06-02, 09:35 AM
  3. bearing and distance lables
    By eleonard in forum AutoCAD Civil 3D - General
    Last Post: 2007-04-24, 08:41 PM
  4. Annotation - Bearing and Distance - Civil
    By Mlabell in forum Dynamic Blocks - Sharing
    Last Post: 2007-04-05, 11:45 AM
  5. Survey bearing distance in revit
    By Wagurto in forum Revit Architecture - General
    Last Post: 2005-03-25, 04:01 AM
Tags for this Thread
