Thread: need help - generating elevations & sections from all my 'constructs' in proj navigator
    2009-05
    109
    Default need help - generating elevations & sections from all my 'constructs' in proj navigator
    I've used autoCAD and Civil 3D for a few years but I am pretty fresh to acad Architecture.
    I am constructing plans for a 2 story home through the project navigator, ive set my levels/elevation values and created constructs for the slab, first floor, second floor, and roof.
    1. How do i combine all these together to create the *assembled* building? - for example, to extend the second floor ext. walls up to the roof line
    2. I have drawn walls with stud 4, stud 6 wall types, will i be able to generate the framing based on this?
    3. I havent seen where i create the floor structure between my first and second floors, or between my second floor and roof. Such as the stringers/beams etc. How do i do this?
    Thanks for all help
    2002-12
    278
    Default Re: need help - generating elevations & sections from all my 'constructs' in proj navigator
    The HELP menu has a pretty helpful tutorial that will get you the full bottle on the PN. You would create view drawings and tick which parts are to be included.
  1. fatal error when generating sections or elevations
    By kgomez in forum Revit MEP - General
    Last Post: 2011-05-11, 03:18 PM
  2. Where to create bldg sections (in constructs or views?)
    By bbarneclo in forum CAD Standards
    Last Post: 2009-04-22, 10:03 AM
  3. REORDER CONSTRUCTS AND VIEWS IN PROJECT NAVIGATOR
    By markklucas in forum ACA General
    Last Post: 2008-04-23, 01:23 PM
  4. Project Navigator Constructs Problem
    By drafting1 in forum ACA General
    Last Post: 2008-01-18, 11:10 AM
  5. Hyperlinks in Proj Navigator
    By sean.59580 in forum Project Navigator
    Last Post: 2006-08-03, 06:55 PM
