Thread: energy analysis building parameters
    2013-02
    4
    Default energy analysis building parameters
    i am using revit mep for HVAC plant design...while doing energy analysis of one the project ...i stuck at a problem. i have to assign 10 peoples and 2000watt light load & 25K watt equipment load for my energy analysis model..how do i do that?????
    i tried by selecting building type dialog in energy analysis tab but wont able customize its parameter as per my requirement..even changing its parameter from heating & cooling load dialog in space type also wont work out in CEA analysis..what to do now???
    2004-06
    Port Moody, BC
    349
    Default Re: energy analysis building parameters
    You should be able to access this info via the space as per my attached image.
  1. ME430-3U: Using Green Building XML (gbXML) for Building Energy Analysis Interoperability
    By Autodesk University in forum MEP Design and Engineering
    Last Post: 2015-08-07, 05:35 PM
  2. ME427-2: Using Green Building XML (gbXML) for Building Energy Analysis Interoperability
  3. Building Construction Types & Energy analysis
    By wblaney in forum Revit MEP - General
    Last Post: 2009-11-04, 03:42 PM
  4. Parameters Grouped Under Energy Analysis
    By jon111712 in forum Revit Architecture - General
    Last Post: 2007-12-20, 08:11 AM
  5. Energy use analysis
    By r.harris in forum Revit Architecture - General
    Last Post: 2005-11-14, 03:53 AM
