Results 1 to 1 of 1
Thread: CP34-1: Extended Entity Data
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CP34-1: Extended Entity Data
    Instructor: Bill Fane
    Class Description: This course has nothing to do with Viagra. Instead, it teaches experienced Lisp programmers how to attach their own data onto existing AutoCAD drawing objects, and how to interrogate this data later. This extended data does not show up in the drawing nor does it appear in AutoCAD’s “List” command, but it is available to knowledgeable programmers. The type of data that can be attached includes plotting parameters, client and project information, vendor and inventory data for component parts, and so on. We will work through an example that parametrically creates a 2D drawing detail of a coil spring and then attaches its specifications to it. If we want to edit the spring later we can read its specs back from the attached data.
  1. CP9300-1: Extended Entity Data
    Last Post: 2014-12-01, 01:42 AM
  2. PR34-3: Extended Entity Data
    By Autodesk University in forum Computer Programming
    Last Post: 2012-11-24, 07:38 PM
  3. PG41-2: Extended Entity Data
    Last Post: 2012-11-19, 03:44 PM
  4. Removing extended entity data
    By JSelf in forum AutoLISP
    Last Post: 2010-06-16, 08:28 PM
  5. Three programs using EXTENDED ENTITY DATA
    By aaronic_abacus in forum AutoLISP
    Last Post: 2007-01-02, 01:13 PM
