Thread: Changing Coarse Level of Wide Flange Beam in Framing Elevation
    2010-10
    Cleveland, OH
    3
    Question Changing Coarse Level of Wide Flange Beam in Framing Elevation
    I am trying to change the wide flange beam family so that in a framing elevation, when the detail level is set to coarse level the single line representation is actually at the reference level for that beam and not in the middle of the beam.
    I know a little bit about modifying families, but when I look at the wide flange beam family I get lost as to where to look for how the coarse level of detail is shown.
    Any help would be appreciated.
    Thanks.
    2001-12
    Irvine, CA
    7,535
    Default Re: Changing Coarse Level of Wide Flange Beam in Framing Elevation
    When you look at the instance parameters of the beam, in the project there is a parameter called: Stick Symbol Location. Change that to "Top of Geometry" and that's where you'll see the stick symbol instead, isn't defined inside the family itself.
    2010-10
    Cleveland, OH
    3
    Wow. I would have never guessed that. I will go try that. Thanks.
  1. 2015: Wide Flange beam encased in Concrete?
    By Andi in forum Revit Architecture - Families
    Last Post: 2015-07-20, 04:37 PM
  2. Bring back shape handles to the wide flange beam family.
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-10-10, 09:33 PM
  3. Tapered Wide Flange Beam
    By abink in forum Revit Architecture - Families
    Last Post: 2007-06-28, 01:03 PM
  4. Hole in Wide Flange Beam
    By rmcelvain.103137 in forum Revit Structure - General
    Last Post: 2006-06-02, 05:10 PM
  5. Two plumb cut for wide flange beam
    By thalim in forum Revit Structure - General
    Last Post: 2005-08-30, 03:18 AM
Tags for this Thread
